nixy82
TTYAMA0 RX/TX/RTS/CTS Overlay for Compute Module
Sat Oct 01, 2016 5:57 pm
Hi
Hope I can get some help here
I'm trying to compile the below devicetree overlay to enable and position the full RX/TX/RTS/CTS pins on the (ttyAMA0) UART0 on GPIO30-33
So far I've put UART1 on 14/15 OK
I've temporarily removed the serial console from the boot cmdline.txt
My kernel running on Jessie is :
root@raspberrypi:~/device-tree# uname -a
Linux raspberrypi 4.1.21+ #872 Wed Apr 6 17:27:13 BST 2016 armv6l GNU/Linux
Device tree compiler is :
root@raspberrypi:~/device-tree# dtc --version
Version: DTC 1.4.0
Here's the code :
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2708";
        fragment@0 {
                target = <&uart0>;
                __overlay__ {
                        pinctrl-names = "default";
                        pinctrl-0 = <&uart0_pins>;
                        status = "okay";
        fragment@1 {
                target = <&gpio>;
                __overlay__ {
                        uart0_pins: uart0_pins {
                                brcm,pins = <30 31 32 33>; /* UART0: CTS0 RTS0 TX0 RX0 */
                                brcm,function = <7>; /* ALT3 */
                                brcm,pull = <0 0 0 2>;
        fragment@2 {
                target-path = "/aliases";
                __overlay__ {
                        serial0 = "/soc/uart@7e201000";
I've found the number for ALT3 from :
https://www.kernel.org/doc/Documentatio ... 5-gpio.txt
This is how I'm compiling it (no errors produced when run):
dtc -@ -I dts -O dtb -o uart0-full.dtbo uart0-full-overlay.dts
cp uart0-full.dtbo /boot/overlays/uart0-full.dtbo
But I get this error when I check vcdbg log msg :
002104.433: Loaded overlay 'mmc'
002127.772: Failed to load overlay 'uart0-full'
002135.698: Loaded overlay 'uart1'
002135.716: dtparam: txd1_pin=14
002136.186: dtparam: rxd1_pin=15
002136.746: dtparam: i2c1=on
002163.148: Loaded overlay 'i2c-rtc'
002163.165: dtparam: ds1307=true
ttyAMA0 appears in /dev, but raspi-gpio doesn't report it working either (no great surprise there!)
Here's the config, dmesg etc
http://pastebin.com/KYWdHfDU
So I'm a bit stuck on what's not working here, are there any gurus that can help?
Andrew.
PhilE
Re: TTYAMA0 RX/TX/RTS/CTS Overlay for Compute Module
Sat Oct 01, 2016 7:09 pm
Getting just that error ("Failed to load overlay 'uart0-full'") suggests that the firmware can't find the overlay file. I think the reason is that your kernel and firmware pre-dates the switch to Dynamic Device Tree support and the new .dtbo extension. You need to either update to a 4.4 firmware or change the name of the compiled overlay to "uart0-full-overlay.dtb".
nixy82
Sat Oct 01, 2016 7:23 pm
Doh!
Yep, that's fixed it :D
002075.740: Loaded overlay 'uart0-full'
  GPIO 30: level=0 fsel=7 alt=3 func=CTS0
  GPIO 31: level=1 fsel=7 alt=3 func=RTS0
  GPIO 32: level=1 fsel=7 alt=3 func=TXD0
  GPIO 33: level=1 fsel=7 alt=3 func=RXD0
Return to “Device Tree”
