arclite
Using a Hall effect sensor with RPi
Fri Feb 17, 2017 12:19 pm
What has happened to the Hall.py file offered in the article by Matt Hawkins, under Raspberry-Pi-Spy.co.uk Home > Hardware > Sensors, dated September 28th 2015? I wanted to try my first bit of Python and to use my Pi for the first time and just my luck to be frustrated. I have bought a big hot water tank to be used with a solar water heater but I want to build a weather monitor to check on the efficiency of my set up. A hall effect sensor will be used for both wind speed and direction. Just how many RPIs will be necessary to monitor a variety of single wire thermometer sensors and I2C humidity sensors is beginning to melt my brain!
In getting to post I lost the article date so I hope somebody will recognise this amongst a series of articles published in MagPi?
wget https://bitbucket.org/MattHawkinsUK/rpi ... on/hall.py
Thank you in advance for any help received.
Alexandra
Ferdinand
Re: Using a Hall effect sensor with RPi
Fri Feb 17, 2017 8:47 pm
Hi arclite,
I rewrote the original hall.py code a little bit. Connect the output of the open collector of the hall sensor to GPIO 17 and use a pullup resistor of ~2.7 k ohm to 3.3 v. If the south pole passes the hall sensor it will turn the output on. This py script counts the passes of the magnet only.
Success with your project!
Try this code:
#!/usr/bin/python
#    ___  ___  _ ____
#   / _ \/ _ \(_) __/__  __ __
#  / , _/ ___/ /\ \/ _ \/ // /
# /_/|_/_/  /_/___/ .__/\_, /
#                /_/   /___/
#       Hall Effect Sensor
# This script tests the sensor on GPIO17.
# Author : Matt Hawkins
# Date   : 27/09/2015
# http://www.raspberrypi-spy.co.uk/
# Import required libraries
import RPi.GPIO as GPIO
import time
import datetime
def sensorCallback(channel):
  global sensorCounter
  global sensorStatus
  sensorStatus = True
  #timestamp = time.time()
  #stamp = datetime.datetime.fromtimestamp(timestamp).strftime('%H:%M:%S')
  sensorCounter += 1
  #print "Sensor LOW " + stamp
def main():
  try:
    global sensorStatus
    sensorStatus = True
    sensorCounter = 0
    while True :
      if sensorStatus == True:
        print "Sensor Counter   ", sensorCounter
        sensorStatus = False
  except KeyboardInterrupt:
    # Reset GPIO settings
    GPIO.cleanup()
# Tell GPIO library to use GPIO references
GPIO.setmode(GPIO.BCM)
print "Hall sensor test program \n"
# Set Switch GPIO as input
GPIO.setup(17 , GPIO.IN, pull_up_down = GPIO.PUD_UP)
GPIO.setwarnings(False)
GPIO.add_event_detect(17, GPIO.RISING, callback=sensorCallback)
if __name__=="__main__":
   main()
Ferdinand
arclite
Sat Feb 18, 2017 11:50 am
Hi Ferdinand, sorry but my problem is that the original file is now missing, the link is broken!
Also when taking about critical stuff like frying a RPi, please refrain from using jargon like ASO and DBM because it frustrates me and possibly other newbies. At least treat us equally by providing a key to these shorthand references. It isn't fair or clever to use this stuff in an "open forum" , it is ok in private messages to friends you know etc. With thanks for your efforts and contributions. Looking forward to being able to put this example to good use, but I and others would need access to the complete file first however if you could help here?
Ferdinand
Sat Feb 18, 2017 12:29 pm
Hi arclite,
Are you looking for this article?
http://www.raspberrypi-spy.co.uk/2015/0 ... pberry-pi/
Ferdinand
Burngate
Sat Feb 18, 2017 4:49 pm
... jargon like ASO and DBM
A.S.O. is "and so on"
DBM could possibly be an abbreviation for the power ratio in decibels (dB) of the measured power referenced to one milliwatt (mW), or mean 9-(6-deoxy-beta-D-allofuranosyl)-6-methyl-9H-purine in the Protein Data Bank. We await Ferdinand's explanation of his signature
Return to “The MagPi”
