tadder
Help Wanted Issue 46 Page 32 Internet Radio
Sat Jun 25, 2016 2:14 pm
Issue 46 Page 32 Internet Radio, schematic I believe should show MCP3008 pins VDD and V_REF connected together. Without this mod the output from CH0 does not vary. Also the maximum output appears to be around 0.48, so I have changed the test on line 16 of the program to >= 0.4, and on line 19 to <0.4.
Unfortunately the Radio OP does not start until the program is closed, does anyone have any idea why this is so?
I hope this is the correct place to ask a question on MagPi progect, or is there an alternative?
Tadder
Re: Help Wanted Issue 46 Page 32 Internet Radio
Sat Jun 25, 2016 2:55 pm
That schematic is completely wrong. Vdd isn't connected to 5V0 or 3V3 on the RPi, so that MCP3008 isn't powered up.
The breadboard diagram (page before) is correct as both Vdd and Vref are connected to 3V3 on the RPi.
tadder
Sat Jun 25, 2016 3:07 pm
Thanks for the response, I should have mentioned that I had noticed this omission and the MCP 3008 is in fact powered, with an output max of 0.48. I did however have to connect VREF to VDD to get any output.
I still can’t see why I get an audio output only after closing the program.
Tadder
Sat Jun 25, 2016 3:23 pm
Try downloading the code from http://magpi.cc/1OG2Y9i
B.Goode
Sat Jun 25, 2016 3:32 pm
This seems to largely duplicate a thread here: viewtopic.php?f=106&t=109621&p=992705&h ... ta#p992705
That seems to be the appropriate place for it.
tadder
Sat Jun 25, 2016 5:08 pm
DougieLawson wrote:Try downloading the code from http://magpi.cc/1OG2Y9i
Thank you for your continuing help. I have downloaded as suggsted, but no change, no sound until I kill the program, at which point stream from selected channed is played.
Just a thought, I am running this on a PI 3, the original was on a PI 2, could there be a connection?
Tadder
Sat Jun 25, 2016 5:30 pm
Nope. Those Magpi programs should run on any RPi with Raspbian Jessie & python3.
tadder
Sat Jun 25, 2016 7:30 pm
Thanks, actually after looking at the code maybe the logic is flawed?
The main program continually polls the value from the pot, but this means that every time the while True loop is entered the program carries out the "killall mplayer" process followed by "mplayer -playlist " + station + 2 " &" regardless of if any change has been detected in the pot.
So maybe the process can't begin to start until the program is killed ?
Tadder
Sat Jun 25, 2016 7:46 pm
Urgh!
from gpiozero import MCP3008
import time
import os
station_dial = MCP3008(0)
Magic = "http://tx.whatson.com/icecast.php?i=magic1054.mp3.m3u"
Radio1 = "http://www.listenlive.eu/bbcradio1.m3u"
def change_station(station):
    os.system("killall mplayer")
    os.system("mplayer -playlist " + station + " &")
station = "http://localhost" # dummy value
while True:
    if station_dial.value >= 0.5 and station != Magic:
        station = Magic
    elif station_dial.value < 0.5 and station != Radio1:
        station = Radio1
    time.sleep(0.1)
My changes should fix it, if the station is already set we won't attempt to change it.
That code is untested because I don't have a MCP3008 and a pot handy.
tadder
Sat Jun 25, 2016 8:45 pm
Thanks a lot for your assistance, really appreciated.
Unfortunately I won't be able to try it out until Monday evening, but I will let you know how it goes.
Thanks again
Tadder
tadder
Mon Jun 27, 2016 7:05 pm
Your code worked perfectly, thank you.
As a newcomer you tend to assume that anything technical printed in a glossy magazine will have been checked before publication and therefore if it doesn’t work it must be your own fault. If nothing else this experience teaches me to approach all articles with some healthy scepticism.
Thanks again
Tadder
Mon Jun 27, 2016 7:21 pm
When I used to help sub-editing the MagPi magazine (that ended in Feb 2015 with the re-launch) we did go through every article and test the code. There were a few articles where the code got completely re-written by the sub-editors because it either didn't work or was just plain ugly (cut'n'paste code) or wouldn't fit the space allocated for the article.
That piece seems to have gone missing.
robthez
Wed Jun 29, 2016 3:22 pm
Ah thanks for catching that, looks like the schematic got changed a bit right at the end of making the feature and we didn't notice it. Code is completely my fault. I've updated the GitHub and we'll be starting an errata section in issue 48
Return to “The MagPi”
