C# program to set I/O Pin
Posted: Tue Oct 30, 2018 8:54 am
by Fan174
I'm not .net programmer but I have to write code in c# programming. I want to understand basic things
How to set input and output pins in c# programming
using Windows.Devices.Gpio;
public void GPIO()
    // Get the default GPIO controller on the system
    GpioController gpio = GpioController.GetDefault();
    if (gpio == null)
        return; // GPIO not available on this system
    // Open GPIO 5
    using (GpioPin pin = gpio.OpenPin(5))
        // Latch HIGH value first. This ensures a default value when the pin is set as output
        pin.Write(GpioPinValue.High);
        // Set the IO direction as output
        pin.SetDriveMode(GpioPinDriveMode.Output);
    } // Close pin - will revert to its power-on state
