Rotating devise on
Posted: Mon Jun 19, 2017 10:10 am
by impakto91
I'm new user. I'm developing a project with raspberry PI 3 model B, I'm choosing Windows 10 IOT because I normally develop my windows application with VB.NET. I bought a official 7" display and unofficial plastic case. The display is rotated by 180° degrees, I tried to find a solution in this forum but I don't know if the solution is the same than Raspbian. Could you please help me? Where can I set the correct position?
Hope someone will help me :)
Have a nice day
Re: Rotating devise on
Posted: Thu Jun 22, 2017 3:04 am
by pauldy
Mount the boot partition and edit the
config.txt file add
lcd_rotate=2
You can also ssh into the pi with administrator and your web access password and edit the file in the EFIESP directory
Posted: Mon Jun 26, 2017 11:42 am
by impakto91
Thank you, I solved by the Device Portal, it is present a function.
Thanks a lot
