ajvnhou123
Rasberry c# dht11 reading
Tue May 09, 2017 5:16 pm
Hello everyone!
Please I am looking for only code for reading temperature and humidity from dht11. I need C# code . I make universal windows application. What i found was a big code 600 lines for iot hub etc... I dont need that. I just need to read this values .
Thanks !
pauldy
Re: Rasberry c# dht11 reading
Wed May 10, 2017 11:38 pm
Here is your problem, you need fairly precise timing with the dht11 so you will need to use the c code to give you that timing. The code you will find on the internet for windows iot works and any shortcuts you take here will only lead to issues down the road.
