ZombieD
Vpn for Win IoT
Wed Feb 08, 2017 3:38 pm
Helo!
There are any VPN client for windows iot core? Should i install the windows to my raspberry?
Gandalf87
Re: Vpn for Win IoT
Thu Feb 09, 2017 2:42 pm
Hello.
Have you tried the following?
1. update package
2. Install OpenVPN package
3. Download config files
4.Edit config & add your credentials
5. Open and edit config
6. replace it (config name) with one you desire-
7. Disconnect run
8. disconnect run
9. enable ip forwarding
10. configure NAT
11. Make the NAT rules persistent
12. save rules and make them apply at the startup
13. configure and enabe killswitch
14. save and apply
15. Don't use your existing internet router as DNS
16.install dnsmasq if possible to accept DNS requests from the local LAN and forward them to external DNS servers
Source: https://support.ivacy.com/kb/how-to-set ... pberry-pi/
Let me know if it worked. (y)
pUnK
Re: Vpn for Win IoT
Fri Feb 10, 2017 10:14 am
If I am not a mistaken, there is no need in installing windows... May be this can help viewtopic.php?f=29&t=158109&p=1112082&h ... n#p1112082
I have already posted a video there where there was a thing that helped to run anything, including any VPN on Raspberry Pi. So, may be yo will find the answer there))
ExaGear Desktop - run x86 apps on Raspberry Pi
pUnK from Eltechs
pauldy
Re: Vpn for Win IoT
Mon Feb 13, 2017 4:07 pm
Right now the only way you can VPN with Win IoT is using ssh tunnels. That said as an IoT device this is normally solved using an ssl http connection so there isn't normally much of a need for a vpn setup and if there is using an external device can get you around that by tunneling your traffic tot he remote network over a vpn connection.
