Trevinlc1997
TCP Server - I allowed through firewall but still nothing
Tue Nov 29, 2016 10:41 pm
Alright so I wrote some really quick sample code to try and get a TCP server online on my Raspberry Pi 3, I did some research and found I had to allow it through the firewall, I did that. it said "OK" but still it didn't work. (I copied and pasted the code on my win32 application and the server starts up just fine).
By the way this is one of my first UWP applications, but I know setting it in this function works because I had my Raspberry Pi connect to a TCP server (the one I copied and pasted to my win32 application) and it sent data fine and everything.
Used this command to allow through firewall:
netsh advfirewall firewall add rule name="Open Port dddd" dir=in action=allow protocol=TCP localport=dddd
Output: OK
Here is my sample code:
void StartupTask::Run(IBackgroundTaskInstance^ taskInstance)
	WSADATA WsaData = { 0 };
	WSAStartup(MAKEWORD(2, 2), &WsaData);
	ADDRINFOW hints = { 0 }, *results = nullptr;
	hints.ai_family = AF_INET;
	hints.ai_protocol = IPPROTO_TCP;
	hints.ai_socktype = SOCK_STREAM;
	hints.ai_flags = AI_PASSIVE;
	GetAddrInfoW(L"192.168.1.143", L"9000", &hints, &results);
	SOCKET hSocket = socket(results->ai_family, results->ai_socktype, results->ai_protocol);
	bind(hSocket, results->ai_addr, static_cast<int>(results->ai_addrlen));
	listen(hSocket, 0);
	char RecvBuffer[500];
	SOCKET hConnection = INVALID_SOCKET;
	hConnection = accept(hSocket, nullptr, nullptr);
	while (true)
		send(hConnection, "Hello!", 7, 0);
karlssja
Re: TCP Server - I allowed through firewall but still nothin
Wed Nov 30, 2016 7:37 am
If you are using port 9000 the command should be
netsh advfirewall firewall add rule name="Open Port 9000" dir=in action=allow protocol=TCP localport=9000
Trevinlc1997
Wed Nov 30, 2016 10:29 pm
karlssja wrote:If you are using port 9000 the command should be
My bad I forgot to update the command but I did use the one you have specified and it still does not work sadly.
dobova86
Mon Dec 12, 2016 9:41 pm
I think you need to declare low level functionality use in the app package configuration. Sorry I can't remind the xml file name at the moment.
