dobova86
New Win IOT build 14376 installed ...
Thu Jul 07, 2016 9:24 am
Ouch ... this morning checking PI3 I found installed new Iot 14376 build.
I see that web management interface doesn't work correctly anymore ... processes, perfomance and app panels don't show infos anymore ...
Is it just my problem ?
:cry:
Ormindo
Re: New Win IOT build 14376 installed ...
Thu Jul 07, 2016 10:58 am
I've had issues with these tabs not loading any data. They only worked during the small timeframe where I updated my workstation from Windows 7 to Windows 10, mostly because I no longer had my company's security software. As soon as the sysadmins installed the W10 version, I no longer had pretty graphs ! I haven't gotten them to add a specific rule for my raspberry yet.
If you're using personal equipment, you could try disabling your antivirus/adblock/... and test it again.
dobova86
Thu Jul 07, 2016 1:33 pm
Thank you for info, but yesterday it worked fine with build 14366. This morning the board was updated to 14376 and then it worked no more.
:twisted:
I suspect something broken in the build ...
mmccullo
Sat Jul 09, 2016 7:13 pm
I see exactly the same issue here. The Apps list never populates in the App tab. It started with the auto-update to 14376 yesterday.
a.a.
Sun Jul 10, 2016 7:33 pm
The release notes mention the fact that some web functions do not work, for instance the apps function. That makes this a rather useless release.....
playbass
Tue Jul 12, 2016 12:32 am
I have experienced the same issue. Somewhat glad to hear it isn't just my RP3
leonardo.daga
Mon Jul 18, 2016 7:54 am
Same issue here.
Luckily I have two SD, one still with 14366.
Suggestion: Don't install this build, is too bugged
mmccullo
Tue Jul 19, 2016 8:03 pm
It would be nice if we had the choice as to whether to install the new build 14376. The one feature I despise in Win10 IoT Core (-Pro) is these automatic updates which cannot be blocked.
I kept a copy of build 14342, but I have to burn a new SD card every day or so because it wants to auto-update to the broken 14376. Microsoft can't seriously think they can auto-update embedded application devices -- especially when this Insider Preview process already shows such updates result in major breakage of previously working features.
UndergroundFun
Wed Jul 20, 2016 6:48 pm
Or you could keep it from accessing the internet.
mmccullo
Wed Jul 20, 2016 8:41 pm
Good idea. Maybe I will setup a traffic block on my home router for the Pi's MAC address.
savignyc
Thu Jul 21, 2016 7:18 am
For disable the auto update on Windows 10 IoT Core look at here :
http://developers.de/blogs/indraneel/ar ... -core.aspx
it's works for me .
iPresentoire iot
www.ipresentoire.fr
French Tech
Return to “Windows 10 for IoT”
