Xpeed
Windows10 on RBPI2 with Touchscreen
Tue Dec 22, 2015 6:11 am
hello greatings,
I am not good at using English. sorry for that..
I just boot RB pi 2 with windows 10, and I want to use touchscreen 7'
I had followed on Youtube movies to connect wires on touchscreen and I had done.
but it did not work. All cables on touchscreen were composed.
I tested RB pi 2 booting using HDMI, that worked and saw screen of booting win10.
Does touchscreen work on Raspbian? or what should I do?
Re: Windows10 on RBPI2 with Touchscreen
Tue Dec 22, 2015 9:16 am
Xpeed wrote:hello greatings,
Windows 10 IoT Core does not support the TouchScreen Function of the RPF Official Touchscreen, the only fully supported one is the "Chalkboard Electronics 7” LCD Capacitive Touchscreen Display""
http://ms-iot.github.io/content/en-US/w ... rfaces.htm
Retired disgracefully.....
ricl
Tue Dec 22, 2015 9:24 am
It is being worked on, but no-one knows when the result will pop out. The support for the screen itself arrived with no warning or fanfare.
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
Xpeed
Tue Dec 22, 2015 11:24 am
thanks for your answer.. i got it and will find another way
Lucky_B
Sat Feb 27, 2016 9:18 pm
I'm having the same problem know (I need a touch display for RaspberryPi running WIndows 10 IoT).
So is there any news on this?
Sat Feb 27, 2016 11:20 pm
Lucky_B wrote:Hi,
There is another post in the Windows 10 IoT Core Forum regarding your query, but from memory you need the February Preview Developer Release, the post you have appended to is out of date, so time for a searching.....
ms_koster
Thu Mar 03, 2016 4:52 pm
I just verified the february (2016) release (Insider Preview 10.0.14262.1000), touch functionality works for the official 7" touchscreen display. The picture is upside down however (or at least within my perception of what should be up, there has been a lot of confusion on top and bottom of this display).
Martin
pauldy
Fri Mar 04, 2016 7:39 am
I just got my official display up and running after reading this. Add lcd_rotate=2 to your config.txt file and it should turn everything to the way it was.
ms_koster
Sat Mar 05, 2016 7:26 pm
Yes pauldy, that solved it for me too. I was going to look into this, but you just saved me a lot of time, thanks! 8-)
