gthvidsten
Can't access USB device in Universal App
Sun Nov 15, 2015 10:03 am
I have a USB device that I have successfully set to use the WinUSB driver, and it shows up on the Raspberry Pi 2 startup screen as a connected device.
I have added it as a capability to the manifest:
<Capabilities>
  <Capability Name="internetClient" />
  <DeviceCapability Name="usb">
    <Device Id="vidpid:1234 abcd">
      <Function Type="classId:ff * *"/>
    </Device>
  </DeviceCapability>
</Capabilities>
Now I try to access it from my Universal App using the following code:
string aqs = UsbDevice.GetDeviceSelector(0x1234, 0xabcd);
var myDevices = await DeviceInformation.FindAllAsync(aqs);
UsbDevice usbDevice = await UsbDevice.FromIdAsync(myDevices[0].Id);
The device is found as I can see it when I debug the myDevices variable, but the final line always throws the following exception:
Error HRESULT E_FAIL has been returned from a call to a COM component
Why?
What can I do to remedy this and make it work properly
"Anything one man can imagine other men can make real."
- Jules Verne
mozzi
Re: Can't access USB device in Universal App
Sun Sep 17, 2017 3:25 pm
Did you ever end up solving this problem? Having the exact same issue.
Clanzer
Mon Sep 18, 2017 2:30 pm
Your welcome to try the example we provided for testing the USB for one of our example projects.
https://github.com/PulseTrainHat/PulseT ... D-Template
Change the VID/PID in the Constants.cs file and the Package.appxmanifest to suit the VID/PID of your USB Device and it should pick it up.
Cheers
Sean
http://www.pthat.com
Return to “Windows 10 for IoT”
