yasharne
no output for VGA screen
Tue Jun 16, 2015 3:37 pm
I have recently installed windows 10 IOT, I don`t have a hdmi screen so I used HDMI to VGA convertor which worked fine with raspbian and arch but now I don`t get any output by this converter in windows 10, is there any way to fix it?
markrad_msft
Re: no output for VGA screen
Tue Jun 16, 2015 8:01 pm
Unfortunately Win10 IoT on the RPi2 will not drive a HDMI to VGA conversion. HDMI to DVI will work. Sorry I couldn't be of more assistance.
Mark Radbourne | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
Tue Jun 16, 2015 8:46 pm
If you can get that stuff running with Raspbian you can copy the /boot/config.txt settings to a WinIoT SDCard and get it working with Windows. It's a pain in the tail to do that but it's not impossible. I had to override the HDMI settings that way to get WinIoT running with my 1366x768 DVI-D monitor.
This is a doctor free zone.
yasharne
Wed Jun 17, 2015 4:33 am
markrad_msft wrote:Hi,
So is it gonna fix or there is no plan to drive HDMI to VGA conversion?
yasharne
Wed Jun 17, 2015 6:21 am
DougieLawson wrote:If you can get that stuff running with Raspbian you can copy the /boot/config.txt settings to a WinIoT SDCard and get it working with Windows. It's a pain in the tail to do that but it's not impossible. I had to override the HDMI settings that way to get WinIoT running with my 1366x768 DVI-D monitor.
thanks for your advice, now I can get output but it has a very bad graphic quality, is it possible to post your config file?
Wed Jun 17, 2015 7:25 am
My config file is gone because my RPi2B is back to running Raspbian.
# Set monitor mode to DMT
hdmi_group=2
# Set monitor resolution to 1366x768 XGA 60Hz
hdmi_mode=81
Docs are here: https://www.raspberrypi.org/documentati ... fig-txt.md
markrad_msft
Wed Jun 17, 2015 8:32 pm
yasharne wrote:So is it gonna fix or there is no plan to drive HDMI to VGA conversion?
The product group declined to comment if this was to be fixed or if this is how it will stay.
Wed Jun 17, 2015 8:35 pm
It's a GPU firmware problem not a problem with your funky Win10 OS. There could be some value in refreshing those Raspberry Pi Foundation pieces that exist in the boot partition on a Win IoT SDCard.
Mehdi zavari
Tue Feb 23, 2016 11:37 am
Open config.txt file on sd ram that windows 10 iot core isntalled then insert this code it below:
hdmi_force_hotplug=1
hdmi_mode=###compatible with your screen ###
hdmi_drive=2
Hdmi_mode should be correct value
Insert codes next line old codes in config file
