raghulan
Raspberry PI 2 - Windows 10 IoT - GPIO LCD
Sun Jun 07, 2015 8:01 am
I have installed Windows 10 iOT on to my Pi 2,
I just need to change the following settings in the config so my lcd which is using gpio pins will work.
Lcd : https://www.sparkfun.com/products/13051
gpu_mem=32 # set ARM to 480Mb DRAM, VC to 32Mb DRAM
framebuffer_ignore_alpha=1 # Ignore the alpha channel for Windows.
framebuffer_swap=1 # Set the frame buffer to be Windows BGR compatible.
disable_overscan=1 # Disable overscan
init_uart_clock=16000000 # Set UART clock to 16Mhz
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 60 6 0 0 0
could you let me know what should I replace the hdmi settings with gpio settings for lcd.
Berndt73
Re: Raspberry PI 2 - Windows 10 IoT - GPIO LCD
Sun Jun 07, 2015 6:10 pm
viewtopic.php?f=105&t=109560
Go down to Jonathan's answer near the end...
HTH,
Berndt
