samusaki
barcode scanner not working
Wed Jun 03, 2015 1:22 pm
I have a Raspberry Pi 2 Model B, my scanner doesn't work in Windows 10 Core IOT.
When I focus a textbox and scan a barcode, nothing happens. I also tried added KeyDown event for the textbox, so that I see in debugger when a key is pressed. The USB keyboard works, but scanning does not. How can I enable this barcode scanner ?
Maybe you have any tutorials for porting driver ?
My question on superuser:
http://superuser.com/questions/923259/s ... rry-pi-2-w
markrad_msft
Re: barcode scanner not working
Wed Jun 03, 2015 8:48 pm
You don't mention the make and model of the scanner. Currently there is a very small number of USB devices that are supported. The list can be found here: http://ms-iot.github.io/content/en-US/w ... herals.htm.
However, if you can put your scanner into HID (human interface device) mode then it will effectively look like a keyboard to Win10 IoT and should work.
Mark Radbourne | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
samusaki
Thu Jun 04, 2015 4:10 am
A say about the model in my superuser question. Symbol Technologies LS2208 USB, it is HID in windows 10 pc, or windows 8.1.
-_____________________________________________-update
Problem solved by hotplugin usb scanner after Pi booted.
markrad_msft
Thu Jun 04, 2015 7:37 pm
Hi samusaki,
Thank you for posting your solution. I will let the product group know what you have found. It would appear the device is not properly recognized during boot.
