johann31
OWIN support
Wed May 20, 2015 12:47 pm
Is there an OWIN support for Raspberry ?
Thanks.
jtanner_msft
Re: OWIN support
Wed May 20, 2015 10:30 pm
Since OWIN requires IIS support, and there is no IIS currently available on Windows 10 IoT Core it is not supported.
You might be able to achieve a similar result however by using Node.js as a web server instead.
I hope that helps.
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
johann31
Re: OWIN support
Fri May 22, 2015 2:20 pm
No OWIN is a lighter version of IIS... not need IIS
markrad_msft
Re: OWIN support
Fri May 22, 2015 11:35 pm
My colleague is only partially wrong.
Katana is an implementation of OWIN that runs on ASP.Net thus it required IIS.
I don't know of an OWIN implementation that will currently run on a IoT device. At this time I would suggest you look at node.js which is currently supported.
Mark Radbourne | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
