rooflz
Z-Stick S2 Drivers
Tue May 12, 2015 3:13 am
I was at the Build conference and received the AEOTEC Z-Stick S2 along with a smart switch. My main goal is just to create a simple application that can turn the switch on and off. I'm trying to follow the 'Build2015_AllJoyn_ZWave_Setup_Guide_v1.0' document however under prerequisites it states that I need a Raspberry Pi2 with the //Build/2015 image. I loaded the latest insider build however when I plug in my z-stick and check the Rasperry Pi device manager via the web I do not see it listed.
Anyone know where I can find this //Build/2015 image? Or where I can find drivers the following drivers?
Aeon Labs DSA02203-ZWUS Z-Wave Z-Stick Series 2 USB Dongle
Aeon Labs DSC24-ZWUS Smart Switch Z-Wave Appliance Module
Thanks for any help that can be provided.
jtanner_msft
Re: Z-Stick S2 Drivers
Tue May 12, 2015 7:40 pm
The most recent build for Rpi2 was released on 4/29, and that should match the version which was used in the labs at //Build 2015:
https://connect.microsoft.com/windowsem ... adID=57782
I hope that helps.
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
rooflz
Thu May 14, 2015 1:46 am
Thanks Jonathan. For some reason I the Z-Stick is not being recognized. I just updated my Rpi2 to the latest Windows 10 IoT Core build (5/12), however still no luck. After plugging in the usb Z-Stick the light illuminates. I check the web interface however I do not see it listed, Should I? The Windows IoT Core Watcher can access my Rpi2 and I changed the firewall settings according to the documentation. When I bring up AllJoyn Explorer it cannot find any devices. Anything special I can do to debug this?
Thanks again for any help.
jtanner_msft
Thu May 14, 2015 6:54 pm
I've heard that sometimes the Rpi2 has issues providing enough power to its USB ports. Can you maybe try using a powered USB hub with the device?
rooflz
Sat May 16, 2015 12:54 am
Tried with a self powered usb hub but the results were the same. Any other ideas? Is there any sort of logging that can be enabled to provide more information?
rooflz
Wed May 27, 2015 3:45 pm
FYI the ZWaveBackgroundService was not running. Once I built and deployed this all devices now show up in AllJoyn Explorer.
