WindowsIoTCoreWatcher
Posted: Sat May 02, 2015 3:07 pm
by hyla
is "WindowsIoTCoreWatcher.exe" working for You? When I click it it seems to be starting up but nothing ever happens ...
Of course with just on "Pi on Windows" it's not yet vital but still ...
Christoph
Re: WindowsIoTCoreWatcher
Posted: Sat May 02, 2015 4:55 pm
by pauldy
The following shows up in the event log for me when the app spins up and crashes. This is after a full clean install of Win10 x64 and VS 2015 RC then WindowsDeveloperProgramForIoT.
Faulting application name: WindowsIoTCoreWatcher.exe, version: 10.0.10103.0, time stamp: 0x553591f8
Faulting module name: KERNELBASE.dll, version: 10.0.10074.0, time stamp: 0x553acf7b
Exception code: 0xe0434352
Fault offset: 0x00000000000218f8
Faulting process id: 0x10e0
Faulting application start time: 0x01d084f782ba0af4
Faulting application path: C:\Program Files (x86)\Microsoft IoT\WindowsIoTCoreWatcher.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: bca3dacb-ceaf-445f-be98-ac8bd98d8ffd
Faulting package full name:
Faulting package-relative application ID:
Posted: Sat May 02, 2015 5:21 pm
by ric96
working for me but the "tick" in the check box vanishes away after some time
Posted: Sat May 02, 2015 6:05 pm
by ArtemAnchugov
I have same problem.
And there is a bug filed on MS Feedback Center that is worth upvoting: https://connect.microsoft.com/windowsem ... ls/1295993
Posted: Sun May 03, 2015 5:38 am
by RandomPiDude
There's a workaround that Ed Dore posted on the IOT Connect forums. There's one typo in his post, which I've corrected below. (Should be corflags, not coreflags). Worked for me.
original source - https://connect.microsoft.com/windowsem ... ls/1295993
Launch the "Developer Command Prompt for VS2015" as Administrator
change the working directory over to "C:\Program Files (x86)\Microsoft IoT"
sn -Vr WindowsIoTCoreWatcher.exe
corflags WindowsIoTCoreWatcher.exe /32BIT+ /FORCE
The first command (sn.exe) tells windows to skip strongname verification of the binary
The second command forces the application to run as a 32bit application
I'm guessing someone isn't testing this stuff on a 64bit OS :-S
Posted: Sun May 03, 2015 9:31 am
by hyla
RandomPiDude wrote:There's a workaround that Ed Dore posted on the IOT Connect forums. There's one typo in his post, which I've corrected below. (Should be corflags, not coreflags). Worked for me.
Works ... thanks.
Christophs
Posted: Sun May 03, 2015 9:45 am
by hyla
The "Galileo Watcher" is detecting the Pi as well (Windows 7) ...
Christoph
