thomasamberg
How to enable SSH?
Fri May 01, 2015 4:15 pm
Hi, is there a way to enable SSH on the Raspberry Pi 2 under Windows 10? Kind regards, Thomas
at2oo1
Re: How to enable SSH?
Fri May 01, 2015 4:19 pm
No SSH available, its Windows ;) use Remote Powershell.
http://raspberry.tips/raspberrypi-tutor ... inrichten/
Meine Projekte auf http://raspberry.tips/
thomasamberg
Fri May 01, 2015 4:28 pm
Thanks a lot.
And just for the record, here's the "official" link
http://ms-iot.github.io/content/win10/s ... rShell.htm
Stanto
Fri May 01, 2015 10:15 pm
thomasamberg wrote:Hi, is there a way to enable SSH on the Raspberry Pi 2 under Windows 10? Kind regards, Thomas
I imagine you would have to port OpenSSH to Windows for ARM and deploy/run it as a service on the Pi 2 but then you'll have the problem of not having the typical suite of software and at that point it may be prudent to run linux instead. Or an ARM port of cygwin suite of software I suppose.
jtanner_msft
Fri May 01, 2015 10:52 pm
SSH is not available in the current build, but it is being considered for an update in the future. For the short term please continue to use remote powershell as was mentioned previously.
Link: http://ms-iot.github.io/content/win10/s ... rShell.htm
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
