lmoss30
Buttons
Sat Sep 26, 2015 7:53 pm
The buttons on the flight Astros Pis how are they wired, do they come of the sense hat direct?sorry if this has been asked before
jdb
Re: Buttons
Sat Sep 26, 2015 8:18 pm
There is an interstitial board fitted to the AstroPi flight models that brings 6 GPIOs through some hardware debounce to the case-mounted buttons.
The button-GPIO mapping is as follows:
UP = 26
DOWN = 13
LEFT = 20
RIGHT = 19
A = 16
B = 21
We actually use a gpio-keys devicetree overlay to implement these buttons. They map to keyboard keys u / d / l / r / a / b respectively, which allows us to use Linux standard event drivers to respond to button presses.
The SenseHAT joystick maps the canonical direction keys (Up/Down/Left/Right) and centre push (Enter) in the same fashion.
Rockets are loud.
https://astro-pi.org
dliloch
Re: Buttons
Sat Oct 10, 2015 1:33 am
I have a python script in a @reboot user crontab. The pygame command to look for a down joystick works fine when running in a command window but not in crontab.(if event.type == pygame.KEYDOWN). so could I test gpio pin 13 instead? I need someway to have the sensehat run a shutdown command since it will be run headless.. If I just pull the power I am worried that I will corrupt the sd card.
thanks...
AndersM
Re: Buttons
Sun Oct 11, 2015 9:39 am
Have you tried this new stick class?
EDIT:
Made a test script called stickpoweroff.py based on the new class:
from sense_hat import SenseStick
import os
stick = SenseStick()
for event in stick:
        if event.key == stick.KEY_ENTER :
            os.system("poweroff")
        elif event.key == stick.KEY_UP :
            os.system("reboot")
And ran it by adding this line in rc.local
python3 /home/pi/stickpoweroff.py &
It seems to work. :)
dliloch
Re: Buttons
Sun Oct 11, 2015 3:46 pm
thanks so much! It worked! :-)
-don
AndersM
Re: Buttons
Sun Oct 11, 2015 4:07 pm
Hm ... how do I turn it on again? ;)
The lack of on/off switch is a bit annoying.
Return to “Astro Pi”
