I'm trying to use your same setup but without success (it seems).timrowledge wrote:It's not an option for the ISS use case but for home use you can connect the astropi via a 40-way ribbon cable and a male-male adaptor. I'll add a photo of my setup when I get to the office.
OK - picture - I'm actually using a 40pin stacker header that passes through the astropi sockets and the cable can just plug on the top. Very convenient.
Sorry experix, but i don't understand the purpose of an heat pipe over the sensorexperix wrote:Could it be improved by attaching a good heat conductor or heat pipe to the sensor?
I'm not that an expert in heat transmission, but i think that in this case the only solution for reading right values of temperature is to keep the sensor (and so the sense hat) far from the pi cpu...not meters but some centimeter would be enough.experix wrote:The heat pipe would keep the sensor temperature much closer to the temperature at the other end of the pipe, minimizing the effect of warm components near the sensor. It's the same principle as the heat pipe you find attached to the CPU in a laptop, except that one is about removing heat produced by the CPU. A CPU heat pipe would probably be a terribly clumsy solution. I'm thinking of something much smaller-- don't know if such things are available, but you could probably make something. Maybe it doesn't even have to be a pipe; just a short piece of thick copper wire.
You can still have some heat from LED matrix if in use. There is no easy solution to this problem, but I will be more than happy to play with it as I like such challenges.mattoni wrote:experix wrote:I'm not that an expert in heat transmission, but i think that in this case the only solution for reading right values of temperature is to keep the sensor (and so the sense hat) far from the pi cpu...not meters but some centimeter would be enough.
Have exactly same led issue - using blackhat hack3r - any ideas?mattoni wrote:I'm trying to use your same setup but without success (it seems).timrowledge wrote:It's not an option for the ISS use case but for home use you can connect the astropi via a 40-way ribbon cable and a male-male adaptor. I'll add a photo of my setup when I get to the office.
A male-to-male pin adapter and a 40 pin ide cable.
When i turn on the raspy, the led matrix has very low brightness and it remains on even after the boot.
(In normal condition the led matrix goes off after a while).
I had my sense hat mounted on a Black Hat hacke3r Mini Kit and it worked without issue? Raspberry Pi A+. Raspbian Jessie. If your running Wheezy, the matrix will light up and just stay on until you do some updates and the sense hat support files.jklondon wrote:Have exactly same led issue - using blackhat hack3r - any ideas?mattoni wrote:I'm trying to use your same setup but without success (it seems).timrowledge wrote:It's not an option for the ISS use case but for home use you can connect the astropi via a 40-way ribbon cable and a male-male adaptor. I'll add a photo of my setup when I get to the office.
Can you post a picture of your solution?alphanumeric wrote:I used a tall stacking header https://www.adafruit.com/products/1979 and put it between my Pi and sense hat. I soldered a proto board to it https://www.adafruit.com/products/2310 Now my temps read ambient. I now also have a spot to mount my RTC module and a few other odds and ends with easy access to the GPIO pins.
No, it's not an operating system version issue,had my sense hat mounted on a Black Hat hacke3r Mini Kit and it worked without issue? Raspberry Pi A+. Raspbian Jessie. If your running Wheezy, the matrix will light up and just stay on until you do some updates and the sense hat support files.
EDIT: Are you sure you didn't get the ribbon cable backwards at one end? The ribbon cable goes over the top of the Pi, the opposite direction from the way it goes if your using a cobbler.
https://www.adafruit.com/products/2339
https://www.adafruit.com/products/2028
Here you go, https://onedrive.live.com/redir?resid=6 ... lder%2cjpg It's my public OneDrive folder. There are a couple of pictures and a video.mattoni wrote:Can you post a picture of your solution?alphanumeric wrote:I used a tall stacking header https://www.adafruit.com/products/1979 and put it between my Pi and sense hat. I soldered a proto board to it https://www.adafruit.com/products/2310 Now my temps read ambient. I now also have a spot to mount my RTC module and a few other odds and ends with easy access to the GPIO pins.
OK, just wanted to make sure you didn't get the ribbon cable on backwards at one end. Even if the stripe for pin 1 is on the correct side, you can still get it wrong if you plug the cable into the wrong side of the board. From the top versus from underneath. Put it on the wrong way and pin 1 or the ribbon cable ends up on pin 2 or the sense hat. This is possible if your plugging in a double sided pin header. On the Pi looking down with the SD card slot on the left it goes.mattoni wrote:No, it's not an operating system version issue,had my sense hat mounted on a Black Hat hacke3r Mini Kit and it worked without issue? Raspberry Pi A+. Raspbian Jessie. If your running Wheezy, the matrix will light up and just stay on until you do some updates and the sense hat support files.
because with the sense hat direct on top of pi,
led matrix works fine.
And the cable is used the correct way
Oh that's really kind of you. Thank you for the pictures.alphanumeric wrote:Here you go, https://onedrive.live.com/redir?resid=6 ... lder%2cjpg It's my public OneDrive folder. There are a couple of pictures and a video.mattoni wrote:Can you post a picture of your solution?alphanumeric wrote:I used a tall stacking header https://www.adafruit.com/products/1979 and put it between my Pi and sense hat. I soldered a proto board to it https://www.adafruit.com/products/2310 Now my temps read ambient. I now also have a spot to mount my RTC module and a few other odds and ends with easy access to the GPIO pins.
I have a circuit board (proto board) mounted to my stacking header. It acts like a bit of a heat shield. If all you have is a stacking header to increase the space, but the space is all open. The heat will still eventually get there. Especially if you Pi is laying flat with the sense hat right above it. I have mine standing vertical so I can read the LED matrix. I flipped the display 180 degrees so the GPIO header is now on the bottom. This lets the heat escape out the top easier. There is a link to pictures in an earlier post I made in this thread. My temp reading is pretty close to ambient. If it's off its only a half a degree or so high. According to my thermostat anyway, and assuming its acurate.BerlinRF wrote:It's interesting and the first time I found a post about a problem I have from the first day on. The Sense Hat on a RPi2 shows a much higher temperature (~30 degrees Celsius in rooms for me) which does make it useless for serious termometer-applications, unfortunately. I always thought about an "design problem" but also considered my unit to be defect, because nobody else posted about this issue. I bought myself some placeholders (2 times "12MM 40Pin Female Stacking Header For Raspberry Pi 2") but as I just see, it reduces the problem but does not avoid it totally (now 26 degrees instead of real 21 degrees).
Thats really disappointing because it disallows to use the Hat in the compact manner it was designed for.
I also do not believe that it can be corrected because the offset (caused due to the heating of the RPi board) is not a linear function ...
