mmk8283
Solved! - Communication device - Touch sensor
Thu Oct 18, 2018 11:40 am
I'm developing a communication device for my son who has cerebral palsy and is non-verbal, I am a novice at writing code, but I have followed an instructable to make a voice recording playback device. The trouble I have is that the code is set up to use GPIO pins to be hooked to physical buttons. My son has limited capabilities for pressing buttons, and I would like to use touch sensors with the adafruit MPR121 board. I have managed to get the MPR121 installed and recognized, but I cannot figure out how to change the code I have from using the GPIO pins to the I2C input from the MPR121 board.
Please please help]
Below is a link to the instructable with the code I used to make a playback device (uses GPIO pins)
https://www.instructables.com/id/Playba ... pberry-Pi/
import RPi.GPIO as GPIO
import time
import os
#variables:
butPressed = [True, True, True, True, True, True, True]#if button i is pressed, then butPressed[i] is False
pin = [26, 19, 13, 6, 5, 21, 20]#GPIO pins of each button
recordBool = False#True if a record is in progress
GPIO.setmode(GPIO.BCM)
for i in range(0, 7):
    GPIO.setup(pin[i], GPIO.IN, pull_up_down=GPIO.PUD_UP)#sets Pi's internal resistors to pull-up
while True:
        butPressed[i] = GPIO.input(pin[i])#checks if a button is pressed
        if butPressed[i] == False:#if a button is pressed
            previousTime = time.time()
            while butPressed[i] == False and recordBool == False:
                if time.time() - previousTime > 1.0:#if the button is pressed for more than a second, then recordBool is True
                    recordBool = True
            if recordBool == True:#if recordBool is True, it plays a beep sound and then records
                os.system("aplay -D plughw:CARD=Device_1,DEV=0 beep.wav")
                os.system("arecord %d.wav -D sysdefault:CARD=1 -f cd -d 20 &" %i)#records for maximum 20 seconds in file i.wav, with cd quality
                while butPressed[i] == False:
                os.system("pkill -9 arecord")#the record is stopped when the button is let go, or after 20 seconds
                recordBool = False
            else:#if recordBool is False, it plays sound i.wav
                os.system("aplay -D plughw:CARD=Device_1,DEV=0 %d.wav" %i)
    time.sleep(0.1)
scotty101
Re: Communication device -- Help with touch sensor mpr121 Please!
Thu Oct 18, 2018 1:30 pm
Have you read the Adafruit tutorial for the touch sensor
https://learn.adafruit.com/mpr121-capac ... lack/usage
There is a section of code roughly half way down that page that give an example of how to read from the different buttons. I'd create a function to read the buttons, and return "stop", "play", "record", "pause", etc or None depending on whether a button is pressed (but wasn't before) and use that returned value to control the recording/playing.
I don't have the sensor to be able to write something for you but can help debug if you share code and enough information.
mmk8283
Thu Oct 18, 2018 1:35 pm
I've spent many hours trying different things... Trouble is, I'm a complete novice to writing code, I will keep looking at examples and trying to modify/merge things together to get something close. Thanks for sharing the info!
scotty101
Thu Oct 18, 2018 4:03 pm
Once you have something close, share it and the error messages that you get and the forum will be here to help.
mmk8283
Wed Oct 31, 2018 1:32 pm
I abandoned the mpr121 chip and used the adafruit AT42QT1070 instead. the device works great now! My son now has a 4 section touch sensitive "see-n-say" that can be used to teach symbols for PECS communication!
Return to “Assistive technology and accessibility”
