rohroh
Assistance for Non-Verbal Child
Thu Aug 17, 2017 12:15 am
Hi, I am working on a project for my own child who is completely blind, learning delayed and Non-verbal.
The long and short of it is that she is attempting to communicate at times by different sounds or actions. What i am looking at doing is to create a Pi based "Box" that has a series of buttons on the top of it for her to press for simple things such as Playing her music, Calling out for Mum or Dad, Asking for Food or Drink etc.
I was hoping to have initially about 10 buttons which will have various textures or shapes on the top of the buttons (3d printer already pumping those out).
My request is that i need some help with the programming of the Pi, I will be putting a small screen on the top for us to view debug etc if needed. I have a small set of computer speakers in it to make the sounds. What i would like to be able to do is trigger the various functions such as playing music from a USB stick after doing a text to speach of "PLAY MUSIC". If the button is pressed again it would stop the music then trigger text to speak "STOP MUSIC" . If she presses the one for Food it should trigger text to speak - "FOOD PLEASE" etc etc etc.
I would prefer that this is written in Python. I will be attaching the buttons to the GPIO pins directly via pull down resistors etc. If we can also Log the various button presses that would be good...
Any help with this project would be greatly appreciated - i don't have enough Python programming skills to do it myself but i am more than happy to document and provide Kudos to those who help out.
bensimmo
Re: Assistance for Non-Verbal Child
Thu Aug 17, 2017 4:11 am
Just pop to the main site, learning/education section and look at the getting started parts.
You'll have the basic code there.
Speach may be harder, unless it's prerecorded voices.
nawbruh
Tue Feb 13, 2018 5:51 pm
I also have a child that is nonverbal/delayed and was looking to create a communication board also. You said that you have already printed out the buttons on your 3d printer. Do you have the specs for those? Or do you have a place where you are posting your progress? Would love to be able to see how someone else is creating theirs! :)
Thanks again and good luck!
Earlton2
Sat Mar 10, 2018 5:14 pm
Sounds and Speech: There is a train set described on web.ncf.ca/fx829 with an early video of it running. This is controlled from an old telephone dial and as the engines move there are sensors under the track to locate their position. These and user commands trigger both sounds and speech out of four speakers. I use a relay to select one of two audio amplifiers and the audio channel to select which speaker.
Engine sounds are produced by system calls to "aplay". In c-code this is system("aplay DDL.wav -q"). In this case DDL.wav is just a short audio file producing sounds for Diesel Departing Left (channel) speaker. It could just as easily be a recording saying "Jam on toast please". If you have aplay loaded and a wav file available you can test this from the command line.
For train arrival announcements I use system calls to espeak with a text string I built up using sprintf(). i.e. system("espeak txt") where txt was a string. Here is my c-code to say "Ambulance, Fire or Police" in English (northern uk accent) or French. Note how the file from espeak is passed to aplay. This is likely much easier in Python but it's not a language I use and ditto re the command line.
if (fEnglish) sprintf(sEmerg, "espeak -ven-uk-north -a50 -p10 -s150 --stdout"
" \" Am bulance, Fire, or, Police \" 2>/dev/null | aplay -q");
else sprintf(sEmerg, "espeak -vfr -a50 -p10 -s150 --stdout \" Ambulance, "
"pompiers, ou, la, police \" 2>/dev/null | aplay -q");
Also notice how the word Ambulance is broken up, and the additional commas, to make the output easier to understand. I don't know French so I had a neighbour come over with the translation and then to listen to the output. There is a switch on the control panel to select English/French.
For the station announcements I use the string "the train arriving on platform on is the 12 27 from Arnprior, stopping at ..." To get real time in there I added an i2c DS1337 real time clock which is used to set the system clock which I could then read and build up the text e.g. "12 27"
You are welcome to both code and circuits if they are any use to you. I had meant to put them up on the web site but I don't see them there so it was just another job on my to-do list!
mikerr
Sat Mar 10, 2018 9:13 pm
This is much easier in python now with gpiozero:
https://projects.raspberrypi.org/en/pro ... omputing/7 - using buttons
.. and see "making a switch" further down.
Gavinmc42
Mon Apr 02, 2018 7:38 am
A chordic keyboard is one way to get more info from a small number of switches.
10 buttons = 2^10-1 = 1023 combinations.
USB numeric keypad?
https://www.tekgear.com/twiddler3-blem-blue.html
http://diy3dprinting.blogspot.com.au/20 ... orded.html
I have seen twiddlers made from boxes and a few switches held in the palm with a strap that goes over the back of the hand.
You could do something like a power glove, finger flex/switches, tiny speaker for audio output and and Zero with USB power bank.
I2S DAC/AMP https://www.adafruit.com/product/3006
Plenty of sensors with breakout boards for motion detection.
https://www.adafruit.com/category/59
Use hand tilt for shift type function chordic keys
All sorts of sensors these days.
https://www.adafruit.com/category/35
Even a laser distance sensor, put one on a finger tip and you have whitecane.
https://www.adafruit.com/product/3317
There are people learning to echo sound from mouth clicks.
Would not an electronic sound generator be easier?
I have been wanting to make a body motion sensing suit for my kid, based on 9 axis motion sensors and SonicPi.
Trying to get him interested in music. dance and some exercise ;)
I'm dancing on Rainbows.
Mon Apr 02, 2018 7:49 am
Speech may be harder, unless it's prerecorded voices.
With an AIY Voicehat it's relatively easy to use Google's text-to-speech service to say your own things.
https://thepihut.com/products/google-aiy-voice-kit
Note:Having anything remotely humorous in your signature is completely banned on this forum.
mahjongg
Mon Apr 02, 2018 11:44 am
+1, you can find more info about the AIY voicehat here: viewforum.php?f=114
keshymarkyz
Thu Apr 05, 2018 2:22 pm
All of these tectums and maximum of those support
bensimmo
Thu Apr 05, 2018 8:12 pm
Also agree on the VoiceHAT, it comes with all the parts , speaker, microphone and images. It also comes with a good way to connect other things too.
It wasn't out when I first responded to this post, but if using the online Voice part, it get expensive as far as I know, as you pay for it according to https://medium.com/@aallan/a-magic-mirr ... a0fea3b4d6
You should be able to use the hardware with other systems though as I think the local 'free' version is restrictive. Also the pay version is restricted in the EU still.
(I've just setup with the 21-2-18 version and it doesn't match the website https://aiyprojects.withgoogle.com/voice/#users-guide for setup instructions to get the .json file, but that for another day)
rohroh
Sat Sep 08, 2018 8:10 am
I am finally getting back to this project for my daughter - unfortunately her health and my disabled son's health have taken up way too much of my time to be able to work on projects like this.
I'll post up some details of what i have been able to get together in the next few days. Hopefully i will be able to achieve what i was hoping to do with a reasonably simple Python script and some second hand parts attached to an older Original model Pi.
Thanks for the tips so far guys. I am taking all the info onboard.
mmk8283
Thu Oct 18, 2018 11:50 am
I am building a communication device for my son as well, I found an instructable that may be helpful to you. However I am trying to modify this code to use I2C from a MPR121 capacitive touch sensor board rather than the GPIO pins. (any help from anyone would be appreciated.) link below
https://www.instructables.com/id/Playba ... pberry-Pi/
mahjongg
Thu Oct 18, 2018 12:24 pm
adafruit makes small interface boards for arduino's and PI's which they support well, among them they have the "MPR121 12-Key Capacitive Touch Sensor Breakout Board".
More info here: https://www.digikey.nl/catalog/en/partg ... FcQAvD_BwE
go read the supplied datasheets and tutorials.
rohroh
Thu Oct 18, 2018 10:51 pm
Thanks Guys,
I have actually managed to get a very simple version of the appliance i am trying to build up and running. My biggest issue at the moment has simply been time to be able to build it.....
Quite simply i have completed the following.
Wired up multiple switches to activate GPIO pins
Written a very basic Python Script that waits for GPIO triggers and then runs aplayer to play a pre-recorded Audio file that had the appropriate words or phrases that my daughter will need.
When i get a bit more time to work on it I will document the whole process and post somewhere and link back to here. I have spoken to a few other parents of non-verbal kids and they are all wanting me to build them units next... so i guess i better get moving on it and get it working...
Return to “Assistive technology and accessibility”
